What would cause a lifter to explode?
Old Jun 17, 2003 | 07:16 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Never seen an exploded lifter until last night. The
(no.6 exh valve) lifter on my friends car was cracked in half with the outher top riding the push rod. What would cause this to happen? I was able to get the lifter out and the bore is fairly clean and the cam seems alright but geeze.
Old Jun 17, 2003 | 07:54 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
How did he know he had a bad lifter? What signs was he seeing?
Old Jun 17, 2003 | 11:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What would cause it:
Heat treating.
As in, improper heat treating. The lifters need to be fairly hard, and if not done properly, they will be brittle. Shock loads are particularly bad for brittle materials, so it all added up to failure here.
Old Jun 17, 2003 | 01:40 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You know I honestly dont have a clue why he pulled the intake but when I seen the engine the top was off. I think he thought his studs pulled out again, and they were starting to pull loose again especially no.3 intake. Anyway I replaced the lifter and ran a compression check 6 was alright but no. 3 hole was dead. Sliped in a screw driver cranked it over and the piston was at the top of the bore but never went down more then a centimeter. Its broke, probabaly the piston sheared in half.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
