High End Forged Pistons
Old Jun 17, 2003 | 02:19 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I got scammed on an internet deal recently. I bid on what was advertised as new CP Forged Pistons. When they arrived, they were used. The lousy POS that sold them to me won't return my e-mails. The pistons look to be in very good condition. No scuffing. No cracks, etc. I thought I might be able to salvage something from the situation by using them in a budget 400 SBC build up. I took them to work, mounted them on the lathe and checked run-out. Each one has a run out of .004 to .007 in the same area. I thought the things were junk but some local builder told me otherwise. He said that high end race forgings will not be concentric. They are built this way to compensate for distortion during high stress. Can anyone confirm this??
Old Jun 17, 2003 | 02:25 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Pretty much all pistons (except REALLY cheap ones) are offset on one side. It's to try to keep the load more above the center of the rod journal. That way more force is applied directly to the crank.
If you look at the top of the piston, there's normally a notch or a dot of some sort. Those all face the front of the engine when you install them. It's a necessity that you install them properly.
Old Jun 17, 2003 | 02:51 PM
wesilva's Avatar
Transmission: 200R4
Thanks AJ_92RS. I have built several performance motors but never had the occasion to measure concentricity. In the past, I just take the new pistons to the machine shop and as side from double checking clearances, that was that.
84z96L31vortec
Aug 20, 2017 12:16 AM
LT1Formula
Aug 20, 2015 09:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
