massive build up on one single exhaust valve
Old Jun 18, 2003 | 12:13 AM
SlowMaro's Avatar
ok so , my 86 motor was lopey as hell, dying, massive los of power, acted like it was seriously off timing even though it wasnt, so i scrapped the car 2 years ago, finally got around to taking the heads of --LB9-- and noticed a seriously build up on one single exhaust valve. what can cause this? the valve looked to be seated nicely.
Old Jun 18, 2003 | 02:19 AM
owned's Avatar
Poor oil control on that cylinder (bad rings or valve seals) would cause that.
It could also be caused by a dead cylinder. The gas would only ignite when it the exhaust valve open and exposed it to the well over 1000* exhaust stream, and crap up the valve.
Old Jun 18, 2003 | 07:36 PM
Damon's Avatar
Yeah, if there's little or no combustion going on in that cylinder the exhaust valve will crud up, since it doesn't get hot enough to burn the stuff off without red-hot exhaust gasses passing over it. Could be just a dead plug or wire on that cylinder or could be you had the exhaust valve hanging open lightly on that cylinder from mis-adjustment or something more serious.
Old Jun 18, 2003 | 09:41 PM
SlowMaro's Avatar
so could the head be bad, or more likely that the rings/piston is dead....?...either way im going to have a machine shop look them over before i stick these on the l03, everyone says these heads are better, so im going to try my hand at gasket matching and bowl polishing...not too sure about anything else, seems like i could do some serious damage if im npot very careful
LT1Formula
20
Nov 14, 2015 12:02 AM
beastin91rs
Oct 9, 2015 07:38 AM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
makaveli09
Aug 12, 2015 09:07 PM
