350ci Chevy engine into '87 Mustang...
Old Sep 25, 2000 | 11:45 AM
G92Joe's Avatar
Has anyone put a Chev. small block & trans. into a Fox-body '79-92 Mustang?
I have the opportunity (350ci/450hp smalblock & a clean'87 Mustang) to do this swap, but not sure if it's too labor or $ intensive?
If done, what trans/rr-end/driveshaft combo was used?
Any info. would be helpful, I'm seriously considering this swap. That is if "serious" & "Ford" can be used in the same sentence......
Thanks, Joe.
Old Sep 25, 2000 | 04:03 PM
ede's Avatar
ede
i've saw drag cars like that. personally i wouldn't do it, but it's not me thinking about it.
ICON MOTORSPORTS
Old Sep 25, 2000 | 04:52 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
not that much work at all.. is it a 5.0 stang? if so all you need is a set of chevy motor mounts, a drill, adaptor kit (around 200 bux from autozone) and a decal stating "built ford tuough with chevy stuff.." the adaptyor will bolt the motor up to the ford V8 tranny... the kit would be a lot cheaper than buying a known good gm tranny, and fabricating a way to mount it, then getting the driveshaft custom cut..
Old Sep 25, 2000 | 11:04 PM
RSS's Avatar
RSS
F*ck that. Just get an engineless thirdgen and you're set.
Old Sep 25, 2000 | 11:52 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
There oughta be a law....
Old Sep 26, 2000 | 12:13 AM
Kevin S's Avatar
Why would you want to waste such a perfectly good engine with a f**d?
Kevin S
10.9 @ 62.87 (1/8 mile)
89 RS 2.8(bored .030)
B&M shift Improver
B&M Mega Shifter
Perma Cool trans cooler
Accel Wires,
Ignition module,
Super coil
Streetrunner chip(for now)
Flowmaster
1.52 Roller rockers
Things You Will Never Hear a Man Say....
Damn, too bad this car isn't a four cylinder.
Old Sep 26, 2000 | 01:54 AM
Guest
Guest
Posts: n/a
I think you might run into a problem with the oil pan and the k-member. The rear sump on a late ford isnt quite as large as the sump on a chevy, and it barely clears.
Why dont you just stick the engine in a thirdgen, im sure you could find one and it wouldnt require any silly modifications to get it to fit in.
Old Sep 26, 2000 | 02:19 AM
Jza's Avatar
Jza
[delete]
[This message has been edited by Jza (edited October 01, 2000).]
Old Sep 26, 2000 | 02:22 AM
Jza's Avatar
Jza
BTW, custom cutting a driveshaft goes for about 90 bucks. Just had one done for a '34. Just for information's sake...
jhawkeye
May 25, 2022 06:33 PM
xkingcodex
Feb 12, 2020 07:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
