tachometer installation
Old Sep 25, 2000 | 05:36 PM
jason86/2.8's Avatar
I want a tach for my car and I saw one I liked at NAPA today for about $40 and I'm wondering could I put it in myself or would I be better off paying someone else to do it. What all does it take, where do the wires go to? Any help is appreciated, as always!
1986 Berlinetta, 2.8L, newly rebuilt 700R4, 3.42 Posi. 128,000 miles and counting.
I've come to realize that I'm gonna have this car till it pukes for good, b/c I'll never be able to bring myself to sell it.
Old Sep 26, 2000 | 01:07 PM
Locry's Avatar
i'm not sure what type of distributor/coil you have... but in a conventional one like mine, contact point/external coil, i hooked up the positive lead from the tach to the ignition terminal of the coil, and the negative lead to the negative terminal of the coil, it's that simple man... the tach gets the pulses from the negative terminal i think...
Old Sep 26, 2000 | 02:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yup! For wire colors & location, you want to splice the tach signal wire into the black/white wire (terminal "A") on the gray connector...
On my Sunpro tach, they just needed the tach signal wire to go the coil; they said to attach the tach's ground wire near the battery. I guess tach's are different in that way, so check your instructions!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
toones
Jan 6, 2016 06:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
