distributor, ignition coil, or .... don't know
Old Jun 19, 2003 | 06:44 PM
Firl's Avatar
ok. this is the situation, my car isn't starting, It has a new cap a new rotor and new spark plug wires and what not.
ok I try starting ... nothing.
I pull a spark plug and keep the wire on it and ground it and try to start the engine. no spark.
ok so I hooked up the spark plug directly to the ignition coil.
It sparks when the car first starts cranking and then sometimes when I stop cranking.
I thought the ignition coil would spark 8 times every time around?
What am I doing wrong? anyone? lol I have an apointment to have the cars mufflers put on tomorrow gotta get it started somehow any help is appreciated.
- Firl
Old Jun 19, 2003 | 07:17 PM
25thanniversZ's Avatar
try checking the control mod on the dist
Old Jun 19, 2003 | 07:19 PM
Firl's Avatar
how would I check it correctly?
Old Jun 19, 2003 | 07:48 PM
couldnt tell ya how to check them,I just have em layin around..if I think its bad I swap it...if id changed everything you have and still have nothing the control mod is a where I would look next. but somebody will pop up here and probably give more indepth info than I and tell you what the prob is
Old Jun 19, 2003 | 08:41 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
check the wires plugging into the cap, the battery wire more specifially. if its lose/broke, that could cause that (the one right by the plug for the tach)
Old Jun 19, 2003 | 09:50 PM
Firl's Avatar
going into the cap i have a set of 4 wires in 1 plug, and a set of 2 wires in the other, want me to check the ones with 2 wires in it?
Old Jun 19, 2003 | 09:54 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
make sure those 2 plugs are plugged in SECURELY. when i first bought my car, i nailed it through an intersection, and the plug with the 2 wires came out just a bit and the car died. after looking over the car for about 20 mintues we finally noticed it. pushed it down, and it fired right up. good luck.
Old Jun 19, 2003 | 10:00 PM
Firl's Avatar
hmmmm
I think ... that might be it. Does the ignition coil need to be grounded?
9192camaro
16
Feb 3, 2019 12:21 AM
midias
Aug 15, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
