383 Crate engine.......
Old Sep 25, 2000 | 10:01 PM
Monkie's Avatar
Ok I dont really understand this 383 thing. Is it really its OWN engine or is it just a bored out 350? And how many versions are there of it?
Old Sep 25, 2000 | 10:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A 383 originally was a 350 block bored 0.030 over with a turned-down 400 crankshaft, 350 pistons and 400 rods. This combination was very popular so manufacturers started making dedicated 383 cranks which were essentially a 400 rod sized for a 350 journal, and pistons with a higher wrist pin which can be used with the longer 350 rod rod rather than the short 400 rod.
1984 Silver Z28, 383 cid long-rod 4 bolt SBC, ARP Bolts, 2 1/2" Cowl w/ Cold Air Induction, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Roller Tip Rockers, MSD6A Ignition, Blaster2 Coil, HEI Distributor w/ Adjustable Advance, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flowmaster Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Sep 25, 2000 | 10:56 PM
R.C. Righter's Avatar
Actually, there are two general classes of '383's'. The first is the bored and stroked 350. Then, there's also the understroked 400. Depends on what you want to do. torque vs horsepower, different power bands, different rev limits, etc.
R.C. Righter
86 Trans Am 5.0L TPI
Old Sep 26, 2000 | 03:48 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Isn't a destroked 400 a 377?
Old Sep 26, 2000 | 07:53 AM
Baz89RS's Avatar
I think Apeiron is right, a stroked 350 gets you to 383 not a destroked 400 !!
Old Sep 26, 2000 | 08:44 AM
Polecat's Avatar
Destroked 400 is a 377. A 350 bored .030 over, with 5.7 rods and special 383 pistons makes a 383. They are totally different than 350 pistons because the wristpin is higher.You can also make a 383 with 6.0 rods, but may cost more in the long run.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Sep 27, 2000 | 07:04 AM
Monkie's Avatar
Originally posted by Tas:
PAW sells 383s in 2 forms. .030 bored out 350 with 400 crank or bored .060 out 400 with 350 crank.
Is there a site for that place??? And you say there is 2 383s? Which one has the most torque? thanks
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
