89 GTA 5.7 TPI cold start stumbles
Old Jun 20, 2003 | 03:32 PM
CC's Avatar
CC
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
Hello, I have a 1989 GTA 5.7 with a cold start hesitation and stumble problem but the car is fine when its warmed up or after 15 minutes of driving/idling. This problem happened 4 months ago and went away but now its back.
Here is the scenario, I will start the car and it will be fine but all sudden the RMP will be jumpy from 600-1200. As I start to pull away, the car will quit. As I am rolling at 30mph, I give it gas and the RMP will go down and I have no power like I am coasting. The car will quit if I dont put it in park at a complete stop but everything is fine once its warmed-up. All the problems gone.
It has a new fuel pump, fuel filter, new spark plugs/wires, fuel pump relay, ignition cap/rotor and EGR valve. Distributor and injectors are 6 months old. TPS and timing adjusted.
All thanks to those that can help.
Old Jun 20, 2003 | 07:56 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Have you cleaned/checked your IAC?
Old Jun 20, 2003 | 08:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
could be from a bad temp sensor coolant or intake
bryan623
Mar 22, 2021 06:43 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
