350 TPI on a budget
Old Jun 20, 2003 | 04:47 PM
GNR4EVR's Avatar
350 TPI on a budget
I blew up my 305 last week, so now I want to go to a 350...I have a budget of about $2,000 not including the install. Everything from the 305 is good except for the bottom end, and I would rather not get anything from salvaged cars if I can help it...
Is this possible? What would I need to look for?
Old Jun 20, 2003 | 04:56 PM
jeffsbluez's Avatar
Car: 91 z28
You can buy a create motor from GM. Part # 12513151. It has a real good bottom end. The motor is complete from the pan to the heads. I paid $1490.00 for mine. I changed the heads ,cam and put a superram setup on mine.
Hope this helps- Jeff
Old Jun 20, 2003 | 05:00 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
a 350 short block and some machine work on the 305 heads (bigger valves etc) ecu from a 350 car, pretty sure the tpi setup is the same for both cars except for the injectors? i could be wrong.. its easily within your budget... dont know how much you'd actually pay for labor.. why not just buy an engine hoist for 150 or rent one and do it yourself? then ya got more money for mods
Old Jun 21, 2003 | 12:08 AM
GNR4EVR's Avatar
Jeffsbluez, that's actually exactly what I had in mind...do you have any timeslips/dyno runs with that combo?
Also, where did you get it for $1490? SD sells it for $1570, but I have a guy who can get it less due to owning a shop, he's going to get me a price on it on Monday.
Old Jun 21, 2003 | 12:38 AM
jeffsbluez's Avatar
Car: 91 z28
check out my sig
Old Jun 21, 2003 | 01:54 AM
Morley's Avatar
Got the same engine from Scoggins/Dickey last year for $1250 + 165 shipping. Sold the 76 CC heads on E bay for $200, took out that lame cam and installed a Summit cam kit and double roller chain set with roller tip rockers on TrickFlow heads.
I wouldn't use the 305 heads on that engine, the CR will be quite high. I'd look for a set of L98 heads (64cc, will be around 9.6:1 CR) in the junkyard and have them cleaned and checked and valve job done.
Old Jun 21, 2003 | 08:59 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You can get a stock 350 shortblock from Speed-O-Motive for $1250 or a 383 stroker for $1350. Shipping is FREE! I have a stroker from them and have been running it for 4 years and am very happy with it. they even sent me a 4 bolt main block since they didn't have any 2 bolt main blocks available at the time.
http://www.speedomotive.com/chevy_sm..._assembled.htm
Now, considering the business I'm in I'd top it off with a set of LT1 heads and intake and still be under your $2000 budget.
Old Jun 21, 2003 | 03:36 PM
89RsPower!'s Avatar
morley i just read your lt1 intake page.. the only thing i dont understand is why.. what benefits would you gain from it?
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
