What blocks have main caps like this?
Old Jun 20, 2003 | 08:10 PM
StangKiller's Avatar
I saw some pics a while back in here of a chevy 350 2 bolt main block and the caps looked different than I have ever seen, it looked like a better design, instead of the caps being pretty much square looking, the caps were angled outward where they attach to the block like this /---\, this was not a splayed 4 bolt conversion but it just had 2 bolts, I was thinking it was just a stock block, but it looked stronger than a regular 2 bolt.
Old Jun 20, 2003 | 09:57 PM
Vader's Avatar
All the front caps are like that. Are you sure the photo wasn't deceiving you? They may have been aftermarket caps, too, but I can't fathom installing two-bolt aftermarket caps.
Old Jun 20, 2003 | 10:41 PM
No, the center caps were like that, that's why I noticed it so much, after some more thought maybe it was a 2 bolt 400 block, with the bigger main journals GM may have spread the caps out at the base.
Old Jun 20, 2003 | 11:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Like this?
Old Jun 21, 2003 | 08:10 AM
Vader's Avatar
SK,
If you can find the link or photo, it might answer a lot of questions.
Old Jun 21, 2003 | 11:30 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Some one probably worked over a 2 bolt main. Theres a machine shop around here that will trade one of thier 4 bolt 350 blocks for a 2 bolt 350 straight across. This guy claims the 2 bolt blocks are stronger when splayed caps are installed. Ive also heard this myth sevral places. I just use what Ive got, usually 4 bolt with aftermaket caps but ive never had a stock main fail...
Old Jun 21, 2003 | 12:58 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
So it's not a splayed 4 Bolt???
Duh - My bust.... I see it is. I've always heard if you splay your caps, it's as strong, if not stronger than an original 4 bolt.
Any truth to that???
Old Jun 21, 2003 | 02:20 PM
Originally posted by AJ_92RS
Like this?
Sorry but no, not like that, I know what splayed caps look like, this was a cast 2 bolt cap, I have searched for the pic but can't find it so far, I'll keep looking and post it if I find it.
Old Jun 21, 2003 | 02:50 PM
Ok, mystery solved I think, I just found a pic of a 400 block on E-Bay, it has the mains like I was discribing, here's a pic
Old Jun 21, 2003 | 06:13 PM
JERRYWHO's Avatar
The 400 block has straight bolts just like a 350 it's just the shape of the caps that make it look like a splayed bolt pattern.
Jerry
Old Jun 21, 2003 | 09:29 PM
Yeah, I knew the bolts were straight, that's easy to tell just looking at it.
C409
Jan 21, 2016 08:29 PM
C409
Sep 23, 2015 04:30 PM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
