Help with knock retard!
Old Jun 21, 2003 | 10:26 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi... Really need some help here..
I'm in the middle of tuning in my car (PROMS) and I get really lots of knock counts/retard in the high load area. Timing is "only" 23 deg max and still It "knocks". I think it is false knocks, how do I know for sure?
- No exhaust leaking
- Exhaust not hitting anything
- Plugs look good
all Ideas are welcome!
/N.
Old Jun 21, 2003 | 10:34 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try posting this on the prom board with a much accurate info as possible about when it happens....
My suggestions:
How much booost are u running? Any type of boost retard device installed currently?
If your main spark map is 23 degree are u sure your not getting more PE spark added in?(just curious sometimes u forget the little things)
Lots of the time u have to add fuel or reduce timing before the knock point that u see, once detonation happens , everything is hotter and its mor elikely to do it again...u need to eliminate the source, not always the same as where the knock is occuring on yoru scanner (try playing with timing or adding fuel before the occurence)
Is your distrib set at the timing that u have prgrammed in your chip?(base timing)
Old Jun 21, 2003 | 10:42 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Ooppss.... sorry I dont have the blower belt on! still I have massive knock retard.
SO
#1 No boost on...
#2 No PE adder
#3 Will check it out, try to add more fuel but I dont run lean...
#4 Yes , 6 deg........
/N.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
383backinblack
Sep 25, 2015 11:31 AM
ericjon262
Sep 11, 2015 06:07 PM
