Valve Seals...Need for TDC w/ Air Compressor??
Old Jun 21, 2003 | 12:50 PM
BAK12484's Avatar
Changing out the valve seals on the 'bird today and I just want to make sure before I go and drop my valves down in the heads....
I'll be using an air compressor to get the job done (well on the plus holes I can actually get to), and am just clarifying whether or not I need to move it to TDC for the cylinder im working on, or will the valves be held in place regardless????
Main reason I am asking is because when I hook up the airhose I can hear air moving (hissing), and am thinking its because the valves are open (or is the hissing normal?)...?
Old Jun 21, 2003 | 01:12 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
on the cylinder your working on, just turn the engine over until u notice that the valves are closed. (not moving) that's it. good luck
Old Jun 21, 2003 | 02:04 PM
ede's Avatar
ede
really doesn't matter, lot of times the air will push the piston down
Old Jun 22, 2003 | 01:16 AM
jimfulco's Avatar
Car: '72 Nova
Transmission: Saginaw 4-speed
If the valves are leaking.... See if you can tell where the hissing is coming from. Can you hear it through the intake?
Old Jun 23, 2003 | 08:45 PM
BAK12484's Avatar
yeah, when it does leak, its through the intake.... on some cylinders however, the crank/pistons move properly and the valves close... others they don't move at all, so I'm assuming I have to rotate the crank to close the valves
Pac J
May 17, 2020 10:44 AM
Fanatic1074
Oct 2, 2015 03:47 PM
