easy advance/retard?
Old Jun 23, 2003 | 02:42 PM
red305's Avatar
How EXACTLY can timing be changed? I've heard of a wire being jumpered but then what? Everyone says its easy but what is "it"?
Old Jun 23, 2003 | 03:30 PM
ede's Avatar
ede
move the distributor to change ignition timing
Old Jun 23, 2003 | 03:44 PM
red305's Avatar
pull it out, and then turn it clockwise or counter? If thats all then is each tooth one degree?
Old Jun 23, 2003 | 04:33 PM
flyway190's Avatar
Everything you need to know about adjusting your timing is in this thread.
Old Jun 23, 2003 | 08:37 PM
red305's Avatar
Ok, I understand everything except, how are you determining the 'degree' of advance/retard? Maybe this has already been explained and I'm just being a dumbass but hehe I'm just a newbie
Old Jun 23, 2003 | 08:47 PM
flyway190's Avatar
The harmonic balancer has a mark on it. If you're on the driver's side and you look just below your water pump at your harmonic balancer, you'll see a tab above it that has numbers on it. You may have to clean it off to be able to read it. When you have a timing light hooked up, the light will flash and you should be able to see the mark. If the mark is next to the 8 on the tab above 0, your timing is 8 degrees advanced. If the mark is next to the 2 below 0, your timing is 2 degrees retarded, etc. It'll make more sense when you're looking at it with a timing light.
armybyrd
Sep 28, 2023 12:16 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Gunner242
Dec 25, 2015 04:49 PM
92projectcamaro
Dec 8, 2015 12:25 AM
3.8TransAM
Oct 1, 2015 07:47 PM
