Open spacer on a dual plane intake?
Old Jun 21, 2003 | 02:56 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Would putting an open plenum 1" spacer on a dual plane intake hurt performance at all. I was thinking of just grinding the middle section of the intake (the wall seperating the two sides), to a sharp edge.
Old Jun 21, 2003 | 07:28 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I dont think it would hurt, it basicly does what you say you wanted to do but adds to the manifold volume. Seeing how higher HP manifolds have this crossflow section, lol including stock intakes.
Old Jun 21, 2003 | 10:23 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
You've essentially got a built engine with a small carb on it, I think any increase in plenum volume will help you. I'd try and get as much as possible considering that you likely have all kinds of clearance between the TBI and hood in your P/Up.
Couldn't help but notice your best G-tech pro time was at zero Celcius - only in Alberta!
Old Jun 21, 2003 | 11:02 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Yes alberta can be cold!!
I know getting more plenum volume will help me, I don't think I can squeze a 2" spacer under my hood, I'll go out tommorow and try to measure the clearance.
Old Jun 22, 2003 | 01:26 AM
jimfulco's Avatar
Car: '72 Nova
Transmission: Saginaw 4-speed
Make the plenum divider a rounded edge, not a sharp one.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
