check engine light
Old Jun 21, 2003 | 06:48 PM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
check engine light
I found out today i had no check engine light bulb, so i put on in, and i have 3 codes
13 Oxygen sensor signal stays lean during warm engine cruise
33 High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
36 Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
can anyone give any advice, as to curing these problems? or should i just take it somewhere?
Old Jun 22, 2003 | 08:13 AM
Vader's Avatar
If your O² hasn't been changed in the last 30-40,000 miles, it's time. Just for grins, you might want to check the connector at the sensor first.
The '33' is a high indicated MAF flow. The cause is almost always a misadjusted TPS - almost. Just yesterday I had a very strange problem with a MAF burnoff relay that was failing and feeding a few volts to the burnoff circuit while the engine was running, completely screwing the MAF readings. It was also my first close inspection of a Painless Wiring harness, and it looked like a very nice, complete setup with all original wire colors and device connections.
The '36' is a failure of the MAF burnoff cycle. That is usually a MAF burnoff relay or connection problem. On rare occasions it can be caused by an intermittent auxilliary oil pressure switch that interrupts the I mentioned the burn off cycle.
And of course you'll want to clear the ECM of codes once you determine the problems and repair them.
Old Jun 22, 2003 | 10:01 AM
IROC of 88's Avatar
Car: 1988 IROC
do you thnik these problems will be fixed once i get a correctly burnt computer chip from ed wright?
Old Jun 22, 2003 | 11:07 AM
Vader's Avatar
Oxygen sensor threshold voltages normally don't get programmed differently. Unless I'm missing something significant, your modifications should not be so severe that the engine wouldn't run normally with the stock programming. You ARE using a PROM for an L98, correct? A few more cubes might affect the '33', but the '13' shouldn't be an issue unless the Jet Stage 2 programming has done something really screwy to the injector constants or fuel map tables.
Old Jul 8, 2003 | 09:03 PM
tonyb's Avatar
IS code 36 always the burn-off cycle?? If so why are the other possible causes listed for that code?? I currently have the same code, and am going to try and solve it this weekend. I am just trying to get all my facts straight.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
