LS1 in a third gen
LS1 in a third gen
I might be able to get a low milage LS1 with the computer and harness and was just wondering if putting this in a third gen is a viable project. Has anyone ever seen or heard of a swap like this? If anyone has any input on how to make this swap possible, I would appreciate any feedback.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Check this post: https://www.thirdgen.org/messageforu...ML/000217.html
Also do a search for "LS1" here, you'll see some other posts that will help.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I've heard of a swap like that, but it takes extensive mods to the motor mount location.
You would probably also need to get y-pipe and trans if possible, it would make the swap go a lot quicker. Even if the swap was expensive, it would be real cool.
the biggest snag I could see is that the LS1 does not have a fuel pressure regulator or return line. The LS1 cars have a built in regulator on the pump so you would have to figure out a way to run a similar system. I'm not sure if it could be adapted to the 3rd gen sending unit or not, KYle
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
Kyle Osterholt
Okarche, Oklahoma
86 T/A 383 TPI
80 T/A Pace Car
73 Opel GT
Don't know about F-body LS1s but the 97-99 corvettes had the fuel regulator up on the fuel rail I believe. Even if I'm wrong about the location, I know they didn't move it to the pump until 2000.
If you're serious about the LS1 swap e-mail me at bnsrslt1@aol.com I can get you in touch with a guy that does nothing but swap LT1 and LS1 engines into 3rdgens and just about any car.
One thing you have to keep in mind is that there is a LOT of weird and very false info out there on swaps. The only way to get the straight story is to ask someone who's done it. I would definitely say an LT1 swap should be easier than the LS1 - but the LS1 is a far better motor stock for stock. And you might as well throw a cam in it while you're swapping it!
1991 RS LT1
every imaginable bolt-on, and an all-forged 355 on the way with an ATI following in '01
2000 C5 Coupe
black/black 6-spd, optional polished rims, 'mostly' stock....
"So what DOES the back of a Mustang look like?"
1991 RS LT1
2000 C5 Coupe
Car: 1985 Trans Am
Axle/Gears: 3.70
This guy did it check out the link http://www.fbody.com/members/bradkiel/index.htm
1985 ASCD Ram Air Trans Am
http://www.execpc.com/~karpsta/home.html
to find out more
to find out more
ambainb
Apr 25, 2016 09:21 PM
