fuel line question
Old Jun 22, 2003 | 10:22 PM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
fuel line question
i have a 88 firebird that had a 2.8 in it, now have a carburated 355 in it. what do i do with the return line, it was leaking on me and i plugged it off, is that the right thing to do or, does the tank need to be vented somehow, because sometimes when i pull out the gas cap there is pressure being let out?
Thanks in advance,
Joel
Old Jun 22, 2003 | 10:25 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Are you using a mechanical or electric pump, because if its an electric the one leaking is the return line, you need a 3 port regulator, it will eventually burn the pump up. If your using a mechanical fuel pump, i would say plug it off.
Old Jun 22, 2003 | 10:45 PM
Car: 1991 Camaro RS
Engine: 305 TBI
im running a mechanical pump, i removed the relay for the electronic fuel pump so that shouldnt be working, i cant hear it and theres not alot of pressure
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
