Car bogs or stalls after a long drive?
Old Sep 28, 2000 | 10:32 PM
CanadianBeast's Avatar
Its an 89 iroc, L98 with all the minor bolt ons. The problem is after I drive on the highway for an hour or so and I come to a light as soon as I get stopped it bogs and sometimes stalls if I don't rev it up a little. If I can keep it running it idles very irregularly and sounds like its gonna stall again. At first I thought it was a lack of gas when I was braking because It was always low when it did but today it was full when it did it. Its really embarasing when your tuff looking and sounding car stallsat a light.
Old Sep 28, 2000 | 11:16 PM
back to top
Old Sep 28, 2000 | 11:22 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm guessing its an automoatic..
Does it still stall/run rough if you put it in neutral when coming to a stop??
If it doesn't, it sounds like a lockup converter soleniod.
It will feel like stopping a 5 speed car without putting in the clutch.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited September 28, 2000).]
Old Sep 28, 2000 | 11:40 PM
It's the stock 700-R4 with a shift kit, stock converter. I've never tried to put it in neutral before but somtimes it does the same when I'm parking the car, I put it into park and once the rpm's drop a little it stalls the same way. Also recently, last week it hasn't been starting very easily when its cold whereas it used to start right a way. I just put in new plugs, accel wires, and accel cap a couple of weeks ago but it didn't solve the problem
Old Sep 28, 2000 | 11:43 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
The lockup converter sol. would only cause problems in gear....hmmmmm
Vac. leaks??
TPS out of whack??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
killer777
Aug 8, 2015 02:47 PM
