when i turn key fans will start but car wont please read im at the end cof my rope
Old Sep 28, 2000 | 05:45 PM
bad camaro RS's Avatar
i have a 92 trans am 350 tpi when i turn the key on sometimes my fans start to run but car wont start but if i turn my key on and fans dont startup my car will start what could this be
Old Sep 28, 2000 | 08:56 PM
84IROC's Avatar
Thats kinda weird because the fans are supposed to come on when you ground the diagnostic link and turn the key on. This should not prevent the car from starting though. Need a techno weeny for this one....
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 29, 2000 | 12:04 AM
GMI FAST's Avatar
Oh-ohhhh... The notorious VATS problem. Try using any spare key you may have. The resistor chip in your usual key may be worn. If it still happens, you may need the infamous "VATS bypass" trick...
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
http://www.mfba.org
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
