intake manifold sealing???
Old Jun 23, 2003 | 08:33 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
i need to install my intake manifold but have a question. i have the 2 side gaskets, but what about where the manifold meets the block? it looks like on my old engine they used silicone. thanks for any help
i need this soon so i can put the motor in my car. thanks
Old Jun 23, 2003 | 09:09 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Ha! Last week I tried installing my intake and after I torqued it down the damn two end pieces squeezed out like a sloppy joe sandwich. So of course when I tried to pull the intake back up, it ripped my intake gaskets to hell. On next attempt, I will use black permatex silicone and throw those pieces away.
Old Jun 23, 2003 | 09:12 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I dimple the block surface at the ends and use silicone :-)
Best stuff i have found for that, all too common for the rubber seals to squeeze there way out while torqueing down or just start seeping oil
use silicone around the wate rports on the intake gasket and use gask-a-sinch on the rest ...messy nasty junk but man will it ever seal for good , u dont want to take one off after sealing it as above :-) lol
Later
Jeremy
Old Jun 23, 2003 | 09:22 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
use plenty on the four corners
Old Jun 23, 2003 | 09:23 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
and make your own gasket on the two ends (front and back) like so...
Old Jun 23, 2003 | 09:24 PM
cr125r's Avatar
Car: 1988 trans am
awesome, thanks guys
Old Jun 23, 2003 | 11:24 PM
OMINOUS_87's Avatar
Agreed just lay a nice thick bead of RTV across the block. Dont be afraid to lay it down thick either, just give it pleanty of time setup after you torque down the intake. Wipe off the extra around the outside of the intake and just give the stuff inside the intake pleanty of time to cure before you go splashing hot oil all over it. I play by the 24 hour rule when installing an intake with an RTV bead.
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
