What Should I do when storing my IROC?
Old Sep 27, 2000 | 03:37 PM
Ryan89IROC's Avatar
I am going to have to store my IROC for three months and was looking for suggestions as to how I should prepare it. Particularly I was wondering about fuel so that it won't go bad. Thanks for any responses.
Old Sep 27, 2000 | 03:52 PM
steve88iroc's Avatar
Car: 1988 IROC-Z
Transmission: WC T5
Store it with a full tank of gas, and add some fuel stabilizer. You won't have any problems with condensation in the tank if you fill it up.
Old Sep 27, 2000 | 11:00 PM
Mike 25th's Avatar
Never cover with plastic - especially on a non paved surface.
Never start car during winter unless you let it get up to normal running temperature - it promotes condensation.
Crack the windows about 1/2".
Cover your tail pipes or stuff something in them - you might save a mouse.
Change your oil and run it though the motor - new oil offers more protection.
Interior - charcoal brickettes or kitty litter in a large bowl will prevent mildew.
Test your antifreeze! I bought my car in FL and it showed up with 90% water in the radiator.
I'm sure you knew most of this, but I read it in a recent post. I looked for it but couldn't find it.
Anything to help "make 'em last!"
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
Check out the T-Ram at my website:
http://www.mylecdekmat.com/mike.htm
Old Sep 28, 2000 | 01:36 AM
Ryan89IROC's Avatar
Thanks for the advice. I just changed the oil and I bought some fuel stabilizer. I hadn't thought of mildew though. I always run 50/50 water and antifreeze and I live in southern Oregon so it doesn't get that cold. I just don't want any surprises when I get back. I miss my baby already! Thanks for the help though.
Old Sep 28, 2000 | 06:51 AM
90 Formula's Avatar
Car: 90 Formula, blue/silver
Engine: 305 TBI
I store mine for about 6 months a year, with fuel stabilizer and a full tank. It always starts right up in the spring. I take the battery out, too, and keep it charged up through the winter. And yes, the mice:found a dead mouse next to the firewall this spring.They can be destructive, so best get some D-Con and traps.
90 TBI 305 Formula
Original Owner
Auto Trans, T-Tops
Completely Stock Except:
--Flow Cooler water pump
--180 T-stat
Old Sep 29, 2000 | 02:08 PM
Mike 25th's Avatar
I just remembered something... DO NOT use Armour All or anything like it on your interior before you put it away either. They are all water based and seriously promote mildew.
I store mine from Nov. 1 to Apr. 1 in New England winters - haven't had a problem yet. I forgot about the battery - 90 Formula is right, definately take it out and keep charged.
100 Posts!!!!!!!
chazman
Aug 28, 2018 03:25 PM
Papaginos
Sep 27, 2015 03:29 PM
chazman
Aug 22, 2015 02:01 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
