Need help with locations
Old Jun 24, 2003 | 07:13 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Can you guys help me out with some locations on my '87 305TPI Trans Am?
Where is the egr valve? Is it really sitting under the plenum?
And where is the O2 sensor? I could not see it from the top. Will I have to access that from under the car?
May need to replace both of those.
Thanks for the help.
Bill
Old Jun 24, 2003 | 07:22 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Re: Need help with locations
Bill
egr valve IS under the plenum. o2 sensor should be on the exhaust manifold (drivers side). down low.
Old Jun 24, 2003 | 11:22 PM
azvolfan's Avatar
How much of a pain is it to take off the plenum?
Old Jun 24, 2003 | 11:53 PM
CamaroX84's Avatar
Not bad as long as you have the right torx bit and some good extensions. You don't need to take off the throttle body. Just undo the bolts holding the runners onto the plenum on each side, and then just loosen the bottom bolts on one side of the runners, to get that side loose. Then you can pull the plenum up and turn it over to the side out of the way with the throttle cables still connected. Don't forget to undo the wire underneath (MAT sensor), the power brake hose, and the fuel pressure regulator tube. You can get to the 02 sensor much easier from underneath.
Old Jun 25, 2003 | 04:02 PM
azvolfan's Avatar
That should help. Thanks for the info.
Old Jun 25, 2003 | 07:44 PM
Vader's Avatar
EGR (The zinc-dichromated thing in the middle that looks like a Pleadean spacecraft):
Oxygen sensor:
Don't forget the extra znti seize compound...
Old Jun 26, 2003 | 05:26 PM
azvolfan's Avatar
Thanks Vader. But I hope these were file photos you had stored and you didn't run out into the garage and take things apart to snap a picture.
Old Jun 26, 2003 | 08:10 PM
Car: 1990 Iroc-Z
lol
Lbibb
May 5, 2016 12:00 AM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
