Caprice cop car shortblock ?
Old Sep 30, 2000 | 06:15 PM
Blade's Avatar
Any good ? LOL I went trough a complete teardown of one of these engines. The bearings looks VERY good in almost as new condition. The engine also has X rods which I heard are better than the plain stuff. What I'm doing is rebuilding it with new bearings and rings. That phase is already complete and now all I have to is slap my L98 heads and TPI on it. What do you guys think of these motors ? Anything special about em other then those X rods ? It was a carbed engine as far as I could tell since it had a fuel pump rod installed. It's also a full roller block.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 30, 2000 | 06:41 PM
Vader's Avatar
Blade,
What year was the engine from?
It's a '93 or newer, you can trash your L98 heads since the heads on the donor engine will way outflow the L98s - by about 20%.
If it's an older engine, you still might want to check the casting numbers and get specifications - you could be surprized. You can tell a '93 or newer since it should be an LT1. ;D
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 30, 2000 | 06:48 PM
Blade's Avatar
Well it was a shortblock... so no heads. I know it's not an LT1 !! LOL LT1s are quite a bit different now arenth they... hehe
Anyway... Mortec.com said it's an 87-95 roller block.
92 Z28 L98 350
Old Sep 30, 2000 | 07:00 PM
Vader's Avatar
Blade,
I missed the shortblock part. I guess that answers the head question. What cam are you installing? If you don't have a lot of cam, you might want to consider some slightly larger valves while the heads are just lying around. Just a thought.
One thing I found from researching 'B' cars and LT1 engines, and the problems with both is that police departments are really hard on drive trains, but they do perform routine preventive maintenance in most fleets. I'm not shocked that the case is in good condition and shows very little wear. I'll bet the transmission didn't fare so well, though.
Later,
Vader
"Make Me Bad"
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
Linson
Aug 21, 2015 02:12 PM
matthew911
Aug 12, 2015 09:38 AM
