454 with 700R-4 trans?
Old Jun 27, 2003 | 08:37 AM
Guest
Guest
Posts: n/a
ok today i'm going to be posting tons of ?? on different boards cuz i want to learn something today at work (thurdays are always slow) so here it goes
i maybe getting a 454 long block for my 91 firebird but i wanted to know if i could keep the 700R-4 i mean i don't want to swap out to a th400 so i wanted to know if a 700R-4 would bolt up to the big block and would the trans hold up with the HP
the trans just got rebuild less then 500miles ago it has a TransGo shift kit and a 2200 Stall (its the old school 27 spline)
anyone know?
(PS to vader i posted this under this board and not the motor swap board cuz my main ?? is is the trans will bolt up to the big block)
Old Jun 27, 2003 | 08:45 AM
ede's Avatar
ede
all SBC, BBC, and 90* chevy V6 engines use the same bolt pattern for the trans, so yes it'll bolt up.
Old Jun 27, 2003 | 08:50 AM
Guest
Guest
Posts: n/a
sweet now my next ? is what HP does a stock 454 put out? i know my trans is good up to 500HP
Old Jun 27, 2003 | 09:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends on what you've actually got.
"Stock" 454 HP has been "rated" anywhere from about 225 to about 425. Who's to say what whatever you've got and whatever it needs that you don't have yet will do after you've got it together and installed.
Old Jun 27, 2003 | 07:51 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
Re: 454 with 700R-4 trans?
anyone know?
Yeah it will bolt up those 4L60s are very strong! And if your getting a 454 i would get a higher stall TC like 3000-3500RPM.
SSBO
MustangBeater20
Oct 29, 2022 09:20 PM
Kaweh
Aug 19, 2015 07:06 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
