Intake Manifold Problem
Old Jun 27, 2003 | 11:58 AM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
Ok this might sound pretty dumb but i cant get to the last bolt i need to take off so i can get my old stock intake manifold off. There is not enuff space to fit a bit or a wrench of any kind. I was getting so desperate i tried needle nosed plyers, lol. I dont know what the deal is, its at an angle so that i cant get a bit in there, and the space isnt wide enuff for a wrench. Any suggestions?
Old Jun 27, 2003 | 01:01 PM
ede's Avatar
ede
with the right wrench or socket one way or another you can get to it and get the bolt out
Old Jun 27, 2003 | 01:46 PM
Syxx613's Avatar
thanks for the advice it worked! i got the bolt out. But now i have my gaskets to put on for the new intake, but i need sealer dont i? What kind of sealer do i put on it? Also with my gaskets i got some rubber sealers too and i only know where 2 go. Any help?
Old Jun 27, 2003 | 08:06 PM
ede's Avatar
ede
for the long gaskets i use k&w copper sealer in a spray can and for the end pieces i use ultracopper RTV if the engine is in the car. i always use fel pro gaskets unless someone else is buying them for me.
Old Jun 27, 2003 | 10:50 PM
Guest
Guest
Posts: n/a
witch is never i bet
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
