Will this cam work for me????
Old Sep 30, 2000 | 08:04 PM
CamaroX84's Avatar
I have a 5.7 TPI motor out of an 88 Trans Am GTA. I have been looking for camshafts. I found in Summit K-Cam kits by Comp. Will these cams work on computer controlled motors like mine? Thanks.
Old Oct 1, 2000 | 08:36 AM
MIKES 88GTA's Avatar
If it's a roller cam it will work and it also needs to be listed as a lsa of at least 112, if it doesn't say roller or costs $100 or less for just the cam then it's not a roller and won't work with out a lot of things changed.
Old Oct 1, 2000 | 03:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You should stay with a roller, they run a whole lot better than a flat-tappet even with the same specs on paper. They are not at all the same shape. You don't need new roller lifters.
Here is the cam for you...
COMPETITION CAMS CAMSHAFT SPECIFICATION SHEET
PART # 08-302-8
GRIND NUMBER: CS 264H-R12
ENGINE: CHEVY SM BLK 305-350
INTAKE EXHAUST
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .480 .480
.006 TAPPET LIFT 264 274
VALVE TIMING OPEN CLOSE
AT .050 INT 3-BTDC 33 ABDC
EXH 46 BBDC 6-ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 108 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 210 220
LOBE LIFT .3200 .3200
LOBE SEPARATION 112
THIS CAM SHOULD USE SPRING # 981-16
This is a roller cam, for the later-model style of block like you have. Definitely replace the springs with the ones Comp recommends, your stock ones won't last long and if you've ever seen what happens to a motor when a spring breaks and allows a valve to fall into a cylinder you will want to avoid stressing your valve springs unnecessarily.
If you have the heads off, get the 266HR instead. It requires machining the heads for the larger springs, unless Comp will spec the use of that cam with the springs that have a smaller diameter at one end to fit the stock diameter pockets..
[This message has been edited by RB83L69 (edited October 01, 2000).]
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
