Car will not start
Car: 88camaro
Engine: 355
Transmission: th350
Car will not start
Ok my car wont start and this is what happened. I had a transmission leak out of my speedo cable so I tightenened the speedo cable fitting at the trans. So I go to get in my car and it starts and it sounds as if my battery is sort of dead. I leave it alone for 2 days and now all my power is draining out of my battery and when i go to turn the ignition the engine has no click all my power is dropping low and my tach is shooting up all the way... can anyone help? Also before I tightened my tach cable it didnt work and neither did my speedo.
Anyone?
Anyone?
Fully charge the battery and load test it.
It appears that the governor cover is a little wet, too. Another leak there? Also, the speedo cable drive adapter/quill on the transmission is sealed by an 'O' ring. You might want to remove it and inspect the ring.
Car: 88camaro
Engine: 355
Transmission: th350
Thanks for the reply Vader, after removing the cable and reinstalling it my tach jumped to 75 grand and when I would turn the ignition the cable sounded like it was stripping it self out at the transmission. After letting my battery charge for a while it finally started. I thought I had a bad ground some where because the tach thing.
