FAQ topic recommendation
Old Jun 28, 2003 | 09:45 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
As silly to some as this topic may sound, I believe that there should be something in the FAQ if there isn't already about fuel filter changeout and how to relieve fuel pressure.
I did the job tonight and still being new to the 3RDGen, I had to consult the "Search" button.
Anyhoo - After 30 minutes of searching, I found my answer.
Simply shut car off, unplug the 3-wire Weatherplug(not sure if thats tech name) that is plugged into something just under the car where the seats would be (on the other side of course). Start the car, run it until it dies, and BOOM - no pressure.
The rest is quite simple.
The only reason I suggest this is because, even though the answer is SO simple, there are QUITE a few wrong directions that have been posted before and this would drastically reduce confusion.
Old Jun 28, 2003 | 10:31 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: FAQ topic recommendation
Wrong in some instances is quite arbitrary. I for example have never had a problem with just shutting off the car, crawling under there with some rags and junk and takin' care of the damn little thing. People have had many ways to release pressure. One example is that you can unplug the fuse for the fuel pump and crank the car a bit to releave the pressure. To do a FAQ you should input all the ways it has been done reliably. You can also write one yourself and email it to Dirk. I think that's how most of the FAQ stuff is in there now.
Old Jun 29, 2003 | 01:46 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Forgive me if this sounds stupid, but wouldn't just removing the filler cap for the gas tank releive the pressure?
Old Jun 29, 2003 | 02:29 AM
NTChrist's Avatar
You'd think so, but I use that technique, and I think I have about 10 years of my life taken off. Being totally coated in gas (even the old testies were burning like hell) can't be good for you.
Sometimes, even if the pressure is totally relieved, the lines will still flow gas. Gravity and all, you know. My guess is that in certain positions the gerotor that drives the fuel engine-bound allows fuel to flow past it. I think it all depends on what position it is in when you shut the car off.
Old Jun 29, 2003 | 04:44 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Make a Tech Article called "Replacing the Fuel Filter" and send it to webmaster@thirdgen.org.
Abubaca
Nov 5, 2016 12:22 PM
drumstixer
Sep 29, 2015 03:02 PM
Numbah-1
Sep 20, 2015 09:31 AM
corey8084
Sep 17, 2015 02:56 PM
greenyone
Sep 8, 2015 08:41 PM
