Zepher....or naybody else that dosent have a stock fuel pump.
Old Jun 29, 2003 | 01:10 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
i saw on zephers site the transam the black one the fuel pump isnt mounted in the tank is it i think its mounted in line i was wonderinf if i could do that with out.Dropping the fuel tank.
Old Jun 29, 2003 | 07:32 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Ya, mine is mounted behind the back seat.
My car was originally carbed so there wasn't anything in the tank, except for the fuel level sender.
I didn't want to bother with dropping the tank to install a pump so I went with the Holley External in-line pump.
Old Jun 29, 2003 | 09:24 PM
tbfirebird's Avatar
Engine: ??????????
Si im going to have to drop the tank and take out thefuel pump.Also in the pictures of the fuel pump they dont show like the white screen that connects to the fuel pump.Also what and where did you buy the fuel lines are they just clamped on tight can that be done i though anything thats above 20psi should have metal threaded fittins not clamped.
Old Jun 29, 2003 | 09:41 PM
Zepher's Avatar
I am using hi pressure fuel line and since there is a flare on the fitting on the fuel pump, I am only using one Fuel Injection style clamp on each end
I am going to eventually change all the rubber to braided lines with -6an fittings.
Old Jun 30, 2003 | 04:03 AM
tbfirebird's Avatar
Engine: ??????????
so is the that the size -6 fitting thats on the end of the 255fuel pump also whats with the -6 and -5 is there a chart that translates this because im new to this type of fitting size.
Old Jun 30, 2003 | 04:17 AM
Zepher's Avatar
Both ends of the pump have rubber lines still. The fittings I tried to use didn't look like they would seal properly.
-6an is 3/8". The AN numbers are all even, -4, -6, -8, -10, etc...
I bought these fittings to go on my LT1 fuel rail and on the hard line on the car,
I already have the -6 to 3/8" pipe, just needed to order these ones since they were on back order for so long.
Old Jun 30, 2003 | 04:20 AM
Zepher's Avatar
these are some of the fittings I am going to be using. Most of what is in the pictures was used on the 82 LT1 swap we did a few months ago.
This is a shot of the fuel rail on the 82 with the braided -6an lines,
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
