Who makes a good one piece oilpan gasket for a 71 400 sb?
Old Oct 1, 2000 | 12:29 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Ive used the cork ones on my last two motors and they all leak over a short period of time. I heard about a one piece gasket for the older blocks. Anyone know who makes it? or have a part number for it?
Thanks,
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Oct 1, 2000 | 03:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No such thing that I know of...
Use the FelPro -R series gasket. Also you can often get a better seal at the ends with silicone than the rubber seal. Fill the grooves in the rear cap and the timing cover with silicone, let it set up an hour or so, then smear some more on that and on the mating surfaces of the pan.
Alternatively you can use no gasket at all and silcone only all the way around, this often works well too.
Old Oct 2, 2000 | 09:19 AM
Polecat's Avatar
May want to check. I have heard that Fel_pro is now making one piece for the older motors. I know someone makes them for the newer motors, but have heard rumor that Fel is making for older smallblocks now.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Oct 2, 2000 | 09:41 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
It was a non-issue for me because I used an aftermarket timing cover (which also leaked at the bolt holes around the cover). I think most aftermarket timing covers are 72 design and later
Old Oct 2, 2000 | 11:52 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thats what IM using a(79)thick front and rear seal pan. I read somewhere that there was a one piece seal for the -79 pans. IM trying to use better quality gaskets this time.
IM buying my gaskets this week(Felpro)maybe the rep from Summit knows.
1992 Trans Am
May 10, 2023 07:19 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
MY87LT
Aug 17, 2015 08:43 AM
