Trans am strut tower adjustment??
Car: 1989 trans am gta
Engine: tpi 5.7
I have an 89 gta and the left front wheel seems to be out of wack.Is there a way to adjust the 3 bolts on the strut tower to correct the tire tow?? or are these set from the factory?? thanks
Car: '89 GTA
Engine: ZZ6TPI
They are adjustable for both caster and camber, but it's not something I would fool with myself. You really need to bring the car to a reputable alignment shop that will set it up correctly using modern, digital equipment. This is especially important when using lowering springs.
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
