Exhaust question....
Old Jun 29, 2003 | 04:51 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
IF my exhaust pipe is 2 1/2 outlet what size does my tip inlet need to be.
2 1/2 or 2 1/4
I know its kinda stupid sorry....
Old Jun 29, 2003 | 05:53 PM
Morley's Avatar
Re: Exhaust question....
2 1/2 or 2 1/4
A tip made for 2.5" outlets should already be expanded to fit over your pipe. As you go back in the exhaust system the previous pipe should always slip into the next one in line (when using slip fit pipe and clamps) This helps prevent leaks in the system and reduces corrosion inside the pipes, since there isn't an edge to be erroded by the gasses and hold water.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
