Engine removal questions?
Old Oct 1, 2000 | 05:28 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
What do i need to remove before lifting the engine?
The car is a fully loaded -89 gta.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Oct 1, 2000 | 09:41 AM
ede's Avatar
ede
trans to engine bolts,all the harnesses, hoses, linkages, motor mount bolts. unbolt the ac compressor and tie it out of the way, if you have ac. i'd take the radiator out. you can look and pretty much tell what has to be unhooked.
-=ICON MOTORSPORTS=-
Old Oct 1, 2000 | 09:57 AM
bad@ss92camaro's Avatar
i would also take out the distributor and set it to the side sometimes its easier to go ahead and leave the trans bolted up and unhook the driveshaft and pull it all out at once so its easier to stab everything back in later (let me know if im wrong ede)
[This message has been edited by bad@ss92camaro (edited October 01, 2000).]
Old Oct 1, 2000 | 10:04 AM
92 camaro 25th anniversarry polo green with 2 gold stripes
89 camaro
Old Oct 2, 2000 | 10:19 AM
Beefy89's Avatar
I pulled the engine and trans together.If you go that route,make sure you unbolt the torque arm also.I didn't take the starter off,and it hung up on the motor mount a little.Also if you unbolt the torque arm,it may move on you a little bit.Just be carefull.
We need Perry Mason
Old Oct 2, 2000 | 10:21 AM
Beefy89's Avatar
Oh,and don't forget the ground straps that connect from the back of the heads to the firewall.
We need Perry Mason
Old Oct 3, 2000 | 12:10 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I took mine out without the tranny. The only way to do it though was to remove the distributor and then the intake so that I could get at the top bolt. This will also make it easier to get at some of the ground straps in the back of the engine and some of the wiring harnesses in the back. -=-mike
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
