Accel Ignition help fast?
Old Oct 2, 2000 | 08:04 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Ok what coil, HEI GM remote mount or will the super coil fit and how do you mount it. Next hich wires do you recomend, 8mm sprial or 8mm super stock? I need answers quick.
87 Z28 305 TPI, Auto, Gutted air boxes, K & N fillters, Dyno Max 3" cat back.
Old Oct 2, 2000 | 08:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
For the coil,,, you have to go with whatever style your car has on it,,, you obviously can't put a top mount coil on a remote mount cap
For the wires,,,whichever has the RFI suppresio,, super stocks work fine tho and do have the RFI suppresion core that I can remember
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Virtual Racing
- intelligence is learned, ignorance is universal
Old Oct 2, 2000 | 08:23 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I have the coil that is not on the top of the cap. More help!
Old Oct 2, 2000 | 09:37 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I just got a set of Accel 8.8mm custom fit wires for $49 plus 25% off at partsamerica.com.
Old Oct 3, 2000 | 07:31 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
The accel coil you're looking for is pn 140011. Mounts right in the brackets your old remote coil came on. $39.99 at Jegs, slightly more but faster service at your local speed shop. Maybe in stock at Advance Auto but I'm not sure.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Oct 3, 2000 | 01:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's also Accel's remote HEI Supercoil... it comes with a wiring harness that duplicates the top of your stock coil. The part # is 140008. The difference between it and 140011 is that the one I'm talking about will -not- fit in the stock spot.
So that's good, cause you can leave your old coil in as a backup. It's bad because you need to find a spot for it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
efiguy
Sep 27, 2015 01:30 PM
