A/C compressor removal on V-belt setups
Old Jul 1, 2003 | 03:03 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have removed all of the A/C from my 87 V-belt set up excpt for the compressor itself. I'm wondering if I can just remove the compressor and the belt tht it uses or o I have to buy a shorter belt that goes round the power steering pump etc? I know there is already a belt there but at the moment they are doubled up.
If I do need to get a shorter belt does nyone know a part# or length tht I need? I'd measure but my car is currently 3000 miles away in Europe.
Thanks for the help
Rob
Old Jul 1, 2003 | 05:15 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
There should only be one belt that goes around the A/C Compressor.
Take that one belt off, and take off the compressor, lines, and the whole heater box and get an A/C Delete box.
You'll have the crank and water pump pulleys having an open slot in the line, but that is no big deal. (maybe the PS pump too come to think of it)
I havn't had A/C on my V belt setups in years. That's always the first thing to go.
Old Jul 1, 2003 | 07:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Yes, there is only one belt that goes round the A/C compressor. However, I believe this belt also goes round the crank and power steering pulley. I just wasn't sure if I should get a smaller belt that goes found the crank and powersteering pulley. A mechanic told me that I should
Thanks again
Rob
Old Jul 1, 2003 | 09:00 PM
I just took that one belt off and havn't ever had a problem.
Did that on my '85 and ran it for 40,000miles, and my '87 that's got about 60k from when it was taken off.
It runs around the PS but the PS also has one that is dedicated to it.
If you look, there isn't a good way to route the belt for the A/C directly, so they made it go around things IE the PS pump.
Old Jul 2, 2003 | 11:24 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Well when I get bak to the car I'll remove it and see how it goes with just the belts that are left.
Thanks for the info.
Rob
evilstuie
Jan 9, 2020 08:29 PM
TheExaminer
Aug 25, 2015 07:34 PM
zayne0
Aug 24, 2015 07:22 PM
Street Lethal
Aug 13, 2015 08:28 PM
3rdgenparts
Aug 8, 2015 07:09 PM
