Homeade fuel pressure reg
Old Oct 2, 2000 | 03:29 PM
jmon92conv's Avatar
anybody made one? A friend made oe up with a screw welded to the top to adjust. Has anyone ever done this and worked? Also on a stock 305TPI, what pressure should I use. I have gutted air boxes air foil, headers, no cat, tinking of prting plenum when I have it off.
Jeremy
92 Z conv
5-spd B&M
alston SFC, few mods, some free, some not
Old Oct 2, 2000 | 04:59 PM
scotty d's Avatar
i have done this mod and have had no problems thus far. i suggest using a fine threaded screw so that when adjustments are made it isn't so sensitive. this is such a cheap mod (about $15 if you don't have a security torx bit, about $2 if you do) i don't understand why more guys don't try this. save your $120 you would spent on a name brand AFPR, this mod will yield the same results. here is a link to a write up on the procedure by Vader. he is write on with the directions.
http://members.aol.com/mmmm999/3rd-d.../afpr/afpr.htm
Old Oct 2, 2000 | 05:19 PM
jmon92conv's Avatar
Thanks, I think I will try it this weekend. What about fuel pressure? How high should I go?
Jeremy
92 Z conv
5-spd B&M
Old Oct 2, 2000 | 07:40 PM
Guest
Guest
Posts: n/a
Its not how high, that is probably not what you want to do. Every car varies between actual output, mods, all sorts of things. You will just need to experiment and see where it performs best. In any case, most people run less than 50 with the vacuum disconnected. Mine is at 46.
Old Oct 2, 2000 | 08:36 PM
jmon92conv's Avatar
Thanks for the responses, I might try it this weekend if I get time.
Jeremy
92 Z conv
5-spd B&M
Old Oct 2, 2000 | 11:42 PM
Vader's Avatar
Originally posted by scotty d:
...here is a link to a write up on the procedure by Vader. he is write on with the directions.
<h1>Warning!</h1>
I wrote the article, yes. I also amended it later to include a clarification about the ball size to use when performing the conversion. Mike hasn't updated the article yet, but here is the link to the updated procedure:
AFPR.pdf
If you don't have the reader to open this file, check the link below.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 3, 2000 | 03:10 PM
jmon92conv's Avatar
Thanks Vader, the one I have already has a disk welded to the bottom of the adjustment nut so I will not have to worry about the ball size. Great article, this site amazes me with info.
Jeremy
92 Z conv
5-spd B&M
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
