Pressure to high?
Old Jul 2, 2003 | 02:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Pressure to high?
Hey, just wanna check and see what you guys think about this....
Over the last few days, my engine ('79 Z28 350) has been running a little rough. I think this is because of the sudden heat wave we just got and is time for a little bit of a tune-up, because the carb was tuned in the winter.
Anyway... a few days ago, I fixed my oil pressure guage, which hadn't been working right for quite awhile (jumping around alot). I just did a fresh oil (10w-30) and filter change about 300kms ago, and oil is still perfectly clean. The engine doesn't burn any oil.
Now... It just seems like my oil pressure is a little high, becuase I know that the highest ay sbc should be is 60-65psi max. I have a pic here showing were the needle is at idle and were it is at regular driving speeds.
Any thoughts?
Old Jul 2, 2003 | 04:58 PM
Air_Adam's Avatar
Anyone?
Old Jul 2, 2003 | 05:09 PM
justinhebert's Avatar
Thats about where mine is. I dont think you need to worry about it. When my engine is hot I get about 30 at idle 50-60 cruising around. With the engine cold I get 65 at idle. What are the symptoms of your engine running rough.
Old Jul 2, 2003 | 05:41 PM
Air_Adam's Avatar
Ok... oil pressure sounds cool then, was just curious about why it was so high at idle.
The running rough is just a rough idle, bit of a tapping sound (exhaust leak, im sure) and a bit of a weird idle condition:
-start it one time, it will idle at about 500 rpm semi-roughly but should be at 750, where I set it. later on in the day, I start it at it will do the same thing, but at 1000rpm!!
I dunno what causes that, other than maybe a bad carb tune for the warmer weather?
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
