Clutch, Flywheel Questions
Old Jul 4, 2003 | 10:15 PM
ChevTech84's Avatar
IS ANYONE RUNNING A CENTER FORCE CLUTCH AND FLYWHEEL WITH A ONE PIECE REAR SEAL BLOCK? MY CAR ORIGINALLY HAD A
TWO PIECE REAR SEAL AND I KNOW THE FLYWHEELS ARE DIFFERENT ON THE ONE PIECE AND TWO PIECE CRANKS, SO I'M
THINKING I NEED SOMETHING DIFFERENT THAN WHAT PART NUMBERS ARE LISTED FOR MY MODEL/YEAR.
Old Jul 5, 2003 | 06:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The clutch is the same. The only difference is the diameter of the hole in the middle of the flywheel, which doesn't affect anything about the clutch.
Lose the CAPS LOCK, it makes your post extremely difficult to read, and comes across AS IF YOU ARE SHOUTING. There is no excuse that makes it OK ("It's easier", etc.)
Old Jul 5, 2003 | 03:22 PM
ChevTech84's Avatar
Sorry for the CAPS LOCK guess I need some typing lessons. So
the diameter of the flywheel is the same, good. When I call Jegs
I should order a flywheel for a later model Camaro. I
was really scared I was going to have to oder the $500.00 clutch
kit instead of the $300.00 kit my application called for. Thanks alot RB.
Old Jul 7, 2003 | 04:39 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
This might be a good time to find a light flywheel. I don't know if it would fit but a L69/ 305HO wheel is pretty light, so's the old L88. But those were from cars with 2 piece rear seals. Anyway, if I was going to replace the flywheel, I'd pony up for the flyweight.
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Trickskier
Aug 29, 2015 01:12 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
