Opinions on "624" heads
I have a set of these laying around and I was wondering if they were worth doing anything with. According to what I've found out these were the heads used on the later LT-1's.
Are these any good, or should I use them to block the wheels when the parking brake goes out of the lawn tractor?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
462624 castings are very thin walled castings. They are not designed for high performance applications. The exhaust seats will crack very easily if the engine gets too hot. (no nitrous, no turbo, no supercharger use)
These heads are 76cc open chambers. The were available with small and large valves. When available with large valves, they also came with screw in studs and guide plates. Intake port volume is only 160.
For what it would cost to rebuild these 30 year old heads, you'd be better off buying a set of Dart heads.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
509 camaro fan
Sep 6, 2015 10:43 AM
Thornburg
Aug 25, 2015 01:46 AM
