Fuel Pump two lines or one line?
Old Jul 9, 2003 | 04:31 PM
Ratchet's Avatar
We are doing the v6 to v8 swap and the V8 is carbed. The V6 had an electronic fuel pump in the tank that I took out. I extended the pick up tube on the sender so that it is now in the same location as it was when the electronic fuel pump was there. Ok enough background I hope.
Here's the question. I can purchase a mechanical fuel pump that has either one or two lines going to the tank. Which one should I get and why. I am hoping that I only need to use one line. The pickup line from the tank as the others are disconected right now.
Thanks.
Old Jul 9, 2003 | 04:44 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
doesn't matter man, if it has two lines to the tank, one is a return line. My car's factory pump had the inlet, the outlet, and the return line, i plugged the return line when i bought a holley fuel pump that only had the inlet and outlet, no problems yet, that was almost two years ago.
Old Jul 9, 2003 | 05:23 PM
Ratchet's Avatar
Thanks for the info. Is there no problem with venting the gas tank so that the fuel will flow.?
Old Jul 10, 2003 | 02:06 AM
Engine: V8
vented gas cap...
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
