volt gauge
Old Jul 9, 2003 | 08:51 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
volt gauge
ok heres the deal, my alternator went out so I replaced it.
gauge read 13/14 as it should, then one day it went all the day down like it was just running off the battery. I did the usually, revved the engine up to get it to spin, nothing. So I took it back cause its lifetime warranty and it was pumping 14 volts so I took it back home n installed it and the gauge read the same. I tapped the dash close to the volt gauge then it went up.
Every now n then it goes down to like 8 and i tap the dash and it goes back up.
How can I fix this? My baby has to have no glitches, even one as minor as this.
Old Jul 9, 2003 | 11:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You could get lucky and find a loose connection to the gauge or source..chances are you'll have to replace it though.
I've the same issue with my car...started about when I had 16K or 17K miles on it.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
