Which cam would make better power?
Old Jul 10, 2003 | 01:44 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Im having trouble finding a roller camshaft that I can use with my stock heads. Im thinking about trying the lt4 camshaft but its pretty mild. ~.460/.480 with 1.6 rockers and a 203/210 duration at .050''
Im gonna get that OR a hydraulic comp cam high energy 268h grind. It has a .454/.454 lift with 1.5s and a duration of 218/218
which of these cams would make better power? Can I go higher on the lift? I will be getting head eventually but not for awhile.
Old Jul 10, 2003 | 01:59 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Both of those cams seem a little mild for a 350. I have a 305 and am going to get a 212/218 with somewhere around .444 lift with a 112 LSA.
Old Jul 10, 2003 | 07:45 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Its always better to get head first, then cam.
Old Jul 10, 2003 | 11:51 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The LT4 will work fine but you will have to use 1.5 rockers or pull the heads and machine the guides
Old Jul 11, 2003 | 07:44 AM
Transmission: 4l60e
Im trying to find something with more duration. Since I have carb I can go alittle higher.
Im gonna go ahead and get a cam now because I cant afford the heads just yet. I will eventually change the heads and when I do I might change the camshaft also.
Both may be mild but they are alot better than the .365/.380 TBI cam thats in my motor now.
I could get the heads with the money Im making from selling my paintball gun but I was gonna use that for a posi and gears.
Head/cam or posi/gear/cam??
theshackle
Sep 17, 2020 08:26 AM
midge54
Dec 27, 2019 04:14 PM
Reborn756
Sep 4, 2015 03:42 AM
355tpipickup
Aug 13, 2015 07:35 AM
Fronzizzle
Aug 9, 2015 01:15 PM
