Header help please
Old Oct 8, 2000 | 01:30 PM
Iroc_Z28's Avatar
Header help please
i have posted in the exhaust section but no one has replied..I was wondering if the flowtech headers without the air tubes will fit my car without modifications...and i was also wondering if they would bolt up to the factory Y pipe...Oh the car is a 87 Iroc Z
with 350tpi thanks for any help
Old Oct 8, 2000 | 04:39 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
no i dont believe the flowtechs will bolt to the factory y-pipe, you have to modify the y-pipe to work
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Oct 8, 2000 | 08:30 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i doubt very much the flow techs would bolt to your y pipe... you would either have to purchase one from them or get a custom one made
Steve
Old Oct 8, 2000 | 09:02 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
will flowtechs even help performance??
why are they so inexpensive at 79.99 compared to SLPs at 500.00??
Old Oct 9, 2000 | 09:03 AM
Iroc_Z28's Avatar
well the main reason that slp headers is so high is that they are 50 state legal. they have all the air tubes and stuff like that on them...performance wise they are not very many exhaust systems that will deliver what they say they will...
Old Oct 9, 2000 | 10:25 AM
86Trans Am's Avatar
Slps are also stainless steel
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Oct 9, 2000 | 02:37 PM
Scrams84Z's Avatar
Car: 1984 Z28
Engine: Custom built 383
Transmission: Tremec 3550
In addition to the SLP's being stainless, it could be the gauge (thickness) of the steel used. I don't know how thick the Flowtechs are, but the thicker the steel , the longer they'll last. A cheap set with thin steel will burn through pretty quick.
Old Oct 9, 2000 | 11:21 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
SLP's have a lifetime gaurantee. Performance wise, I am very happy. I did lose some bottom end. Get it to about 2000-2500 and it takes off! These are 1 and 3/4 headers, on a 350, jet hot coated, and SLP cat back (still stock cat). No other major mods except for the MSD ignition, and the MSD Blaster SS coil. My exhaust got taken out by PA RT 202 so I replaced it w/ the best
Oh yeah, sounds great too. Very low rumble, loud behind the car, not in it. Overall a very good system
Corry
Old Oct 9, 2000 | 11:26 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Flowtechs also have TINY primaries...1.5" if I'm not mistaken. That's way too small for a 350. BTW, last time I checked SLP had their 3rd gen hearder on sale for $350.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP cam, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax/Flowmaster catback
Coming Soon - Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - STOCK (for now)
SOLD ->91 Z28, 5.7, 3.23, Ported Plenum, Accel runners & lower intake, Accel distributor module, !dual cats, POS Edelbrock catback, K&N'S, ram air, tb airfoil, !tb coolant
Old Oct 9, 2000 | 11:48 PM
Jester's Avatar
1. It's not that Flowtechs are so cheap..it's that SLP's are so overpriced. There are several very good brands of header available for under $100.
2. NO headers can use the factory Y pipe. All require the use of an aftermarket pip or a custom made one.
3. Flowtechs have 1.5" primaries, which depending on your engine combo, may or may not be what you want. For pretty much any 305 you want 1.5". As my own rule of thumb I say a 350 under 300hp or so(in other words, most of TPI 350's) should have 1.5" too, under 400 should be 1 5/8, and 1 3/4 for over that. Bigger is NOT always better.
4. I have Flowtechs on my 305, and am extreamly happy with them.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
