Possible clearance issues...
Old Jul 11, 2003 | 04:44 PM
My355Camaro's Avatar
I posted this in the TPI forum, but maybe I will get more responses here...
I have an 1989 Iroc. As you all know it has the 350TPI/Automatic. I just purchased a Hydraulic Roller cam for it. The cam is the Crane Powermax and it has an advertised duration of 284/292 and a lift of .509"/.528". Will this be a problem with the stock pistons with valve clearance? I also understand that the PROM will have to be reflashed but will it run decently in the meantime until i can get it reflashed?
Old Jul 11, 2003 | 05:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably won't be a problem with the pistons, but your retainer-to-guide clearance will be.
That's a lot of cam for a stock PROM.
Old Jul 11, 2003 | 06:14 PM
So what do i needto make it all work with the retainers and guides?
Old Jul 11, 2003 | 07:34 PM
ede's Avatar
ede
machine the head, replace the springs and trash the factory rotator set up and use aftermarket retainers, while you're at it might was well machine the head and trash the pull out studs.
91 SrS
Oct 7, 2015 04:32 PM
86z89iroc
Oct 5, 2015 01:04 PM
Night rider327
Sep 16, 2015 02:20 AM
gta892000
Sep 16, 2015 12:40 AM
