Emergency- STARTER WIRING ON 91 RS
Old Jul 11, 2003 | 07:10 PM
SeanP_92RS's Avatar
WHAT COLOR WIRES GO TO WHAT POST ON THE STARTER PLEASE ASAP EMERGENCY
:hail:
Old Jul 11, 2003 | 07:13 PM
Odyssey's Avatar
Uhh let's see the big wires go to the big post and little wires go to the small post close to the block... easy huh.
Old Jul 11, 2003 | 08:56 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
little more to it then that... The orange-red colored fuseable links, as well as the lead from the positive terminal go to the large post on the solenoid. The red/black (?) wire from the ignition goes to the terminal marked 'S'. There is another terminal there marked 'I' if i recall. This one supplies 12v for any ignition or other components that need it. Dont hook any wires to this. Otherwise, the solenoid wont get power and the starter wont work.
edit: opps... didnt see you already said to put the solenoid cable on the block side of the solenoid.
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
