What Mobil 1 oil weight do I need.
Old Jul 14, 2003 | 12:42 AM
joshwilson3's Avatar
Old Jul 14, 2003 | 02:16 AM
OMINOUS_87's Avatar
10-30
pat12spe's Avatar
5W-30 is what I use for my 305 TBI. I've always used that and I've just hit 108,000 on my car the other day. Engine is running stronger than ever. The motor oil that is used for higher mileage engines really doesn't do much unless you're experiencing some problems. I hear from the commercials that these oils can actually replenish the seals in your engine but I think that's a bunch of doo-doo. Just stick with the 5W-30 and you should be fine.
Old Jul 14, 2003 | 02:29 AM
Old Jul 14, 2003 | 05:03 AM
ede's Avatar
ede
i'd use heavier in heat and thinner in cold
Old Jul 14, 2003 | 10:44 AM
Steve89GTA's Avatar
I agree with ede. I use 10w30 in my GTA in the summer. Don't drive it in the winter so that really doesn't change.
Old Jul 14, 2003 | 11:50 AM
Old Jul 14, 2003 | 11:53 AM
Steve89GTA's Avatar
5w will never hurt anything. For warmer climates on higher mileage motors, I'd us 10w30
Old Jul 14, 2003 | 12:00 PM
Old Jul 14, 2003 | 12:01 PM
OMINOUS_87's Avatar
Run 5-30 when less then 60 degrees outside. Otherwise run 10-30 the rest of the time.
Old Jul 14, 2003 | 12:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: What Mobil 1 oil weight do I need.
Originally posted by joshwilson3
What is the advantage of using 0W-30? How is that different than the others?
What they say - "0W-30 Enhanced Fuel Economy Formula". Thinner oil takes less power to pump through the engine. Since that is the "W" number, it applies when the oil is cold (or, at least, not hot).
I'm using AMSOIL 0W-30 in most of my vehicles. The difference between mileage with it and 5W-30 or 10W-30 is small, but when multiplied by all the vehicles on the road, becomes more significant (but still a small percentage of total consumption).
Old Jul 14, 2003 | 12:16 PM
Old Jul 14, 2003 | 12:29 PM
five7kid's Avatar
I run it year round.
10W-30 should be just fine.
Another tidbit of information: Why 5W-x oils exist. 20 years ago, North America went through a prolonged cold snap, with temps at -20 F for a couple of weeks over a large part of the country. People using 10W-30 and 10W-40 petroleum oils, whose cars sat outside all night, would go out in the morning, start them up, and drive off. Problem was, the oil was too thick for the pump to pick it up, and the car companies paid for a whole bunch of warranty engines with wiped out bearings. They went to the oil companies and said they wanted a pour point of -20 F. The compromise was to impose the -20 F pour point on 5W oils, but not 10W on up weights. Notice that I included the "W" in each statement above, because the "W" is the cold temp rating.
FWIW, none of the car companies paid for a single engine that had Mobil 1 or AMSOIL in it that winter (for that reason, at least).
Any of the Mobil 1 oils you mentioned in your original post would be fine to use year round. The only one that is at all marginal is the 15W-50, and only because it really isn't needed and the extra thickness would cause unnecessary and completely avoidable drag. There wouldn't be any other harm, though.
Old Jul 14, 2003 | 12:59 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
whats the matter with 20-50 don't you want the heaver oil in the summer for better lubrication?
Old Jul 14, 2003 | 02:27 PM
five7kid's Avatar
Doesn't necessarily work that way. With synthetics, it's typically a waste (although you're still getting better lubrication and efficiency than you would with any petroleum oil).
Old Jul 14, 2003 | 04:59 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
so what everyone i ssaying is that the higher milage engines should not go out and buy the higher milage formula unless problems are arizing?
what if you valve seals need changing? would that be enough to get 10w-30 highermilage formula mobil 1 synthetic?
Old Jul 14, 2003 | 05:37 PM
five7kid's Avatar
Vavoline says they add seal softening agents to their high mileage oil. That won't fix seal wear or cracking, though, only hardened seals (and most likely won't help SBC valve stem seals in any way at all).
Mobil 1 Higher-Mileage Vehicle Formula is a synthetic/petroleum blend with seal conditioners. It costs less than full synthetic, so it won't cost you as much to add oil as the older engine burns it. It also isn't a bad choice for synthetic change-over, as it will help clean up deposits left by petroleum-based lubes. Just change it sooner than you normally would.
Old Jul 14, 2003 | 07:46 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
WOW! Ive been using 15/50 mobil1 syn for the last 3 years, is that bad?
Old Jul 14, 2003 | 08:06 PM
Old Jul 14, 2003 | 08:34 PM
five7kid's Avatar
The "weight" that is assigned to a particular oil means that viscosity falls within a certain range. The "W" number represents the viscosity range at low temperature, and the number w/o the "W" represents the viscosity range at high temperature.
In general, a 30 weight oil will be thicker at high temperature than a 40 weight oil. But, since the ranges overlap a little, it is possible that the 30 and 40 weights are exactly the same thickness at high temperature.
Your change-over plan would be okay. If deposits aren't particularly heavy, though, you could run it for whatever drain interval you chose right from the beginning.
Having used the 15W-50 oil isn't "bad", it's just been taking more power to pump it around than necessary without any extra protection benefit.
Old Jul 14, 2003 | 08:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
"In general, a 30 weight oil will be thicker at high temperature than a 40 weight oil"
You sure about that? It'd seem to me the 40 weight oil would be thicker...temp for temp?
Old Jul 14, 2003 | 09:03 PM
five7kid's Avatar
Oops, change "thicker" to "thinner". I was going to say the 40 was thicker than 30.
Sorry about that. Good catch.
Old Jul 14, 2003 | 09:38 PM
Old Jul 14, 2003 | 10:37 PM
OMINOUS_87's Avatar
Ok this is really starting to get out of control!!!! Is anyone paying attention here???
Its like this:
1. Synthetic provides greater protection and longer change intervals.
2. If the outside temp is over 60 degrees run 10-30 syn.
3. If the outside temp is under 60 degrees run 5-30 syn.
4. Anything over 10-30 syn is overkill unless you spend most of your driving time at WOT, but as hot as factory 3rd gen runs 10-40 aint gonna rob much power at all if any, 15-50 is well beyond the requirement of any street car no matter what your mods are.
5. You folks dont own race cars, you own low compression smogger TPI motors, the factory fill is fine to run as well all year round.
6. If you are having a hard time understanding what "viscosity" means, use the damn search button indtead of keeping this thread alive.
Hope this helps!
Old Jul 14, 2003 | 11:07 PM
Old Jul 14, 2003 | 11:21 PM
25THRSS's Avatar
Just go with the 5w-30 year round. If you dont feel comfortable with an oil that thin then just use the 10w-30 year round. Either will work good, and as others have stated anything heavier than that isn't necessary. I run 5w-30 mobil 1 in my LS1, my LT1, and my L03.
Old Jul 14, 2003 | 11:23 PM
OMINOUS_87's Avatar
If you want to keep one grade all year round that is fine, there is more then enough info here for you to be able to make that choice.
If you want further info on 0-30 you need to cal Mercedes Benz and talk with one of their engineers about bearing clearance and oil pump pressure, LOL!!! Right now I cant think of any American cars that have 0-30 as a factory fill.
Old Jul 14, 2003 | 11:25 PM
Old Jul 14, 2003 | 11:27 PM
25THRSS's Avatar
I personally think it's a little too thin, but I seriously doubt you would hurt anything.
Old Jul 14, 2003 | 11:30 PM
Old Jul 14, 2003 | 11:33 PM
25THRSS's Avatar
I don't know, evidently mercedes uses 0w-30 as a factory fill and they must have a reason for it. Most chevy's use 5w-30 as factory fill. They most likely also have a reason for it.
Old Jul 14, 2003 | 11:40 PM
Old Jul 15, 2003 | 12:31 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
What oil would be good for 0 degrees to 90?
5-30 syn I assume
Old Jul 16, 2003 | 04:35 AM
IROZINCO's Avatar
Weight of Oil
Hmm - interesting. I live in Colorado where it gets into the 90's in the summer and the -20's in the winter. (sometimes it can do all that in one day, well, almost!) I have an 87 350TPI with 125k on the engine, in the winter I run 10w-30 and in the summer I run 20w-50. When I am running the 20w, oil pressure is 60+ PSI cold and 45-50 PSI hot idle. 10w-30 will get me 50-60 PSI cold and 30 PSI hot idle. Isn't more PSI ( up to a point of course) better? I would think you'd want to run the oil that your car is happiest with, and that's gonna vary depending on your car, and the driving conditions.
Old Jul 16, 2003 | 11:42 AM
level's Avatar
Car: 1987 transam
ok so 10-30 is good for the stock engine what if you're running a high performance engine 500hp+ say a 383 or a 400 and you're at WOT alot?
Old Jul 16, 2003 | 11:47 AM
Old Jul 16, 2003 | 05:47 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
When the throttle is wide open
Old Jul 16, 2003 | 09:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run 15-50 in My Formula, Lumina, and Maxima , and 10-30 in my grand Prix
Hotrodboba400
Dec 10, 2019 07:07 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
