guess what i broke now!
Old Jul 14, 2003 | 06:03 PM
icebird_1981's Avatar
anyway stupid me last night showing off anyway i hit the gas from a stop and i am spinning like crazy then the car start to vibrate and it almost sounds like one of my rotors are ratteling around. so i stop do the oh $hit oh $hit line thinking i blew out one of my tires. but all looks fine so i park thinking its just from spinning to much. so today i go to drive to work and the sound is still there, i check to see if all nuts are on good then i think its the bareings on my drive shaft and no. so i take off one tire and turn it by hand and i can here that same moveing around parts sound comeing from the diffrencial (sp). so i just dropped it off at a shop and i call tomorrow to find out whats up. is this my falt>like did i just spin to much or was it bound to happen from something commeing loose in there? i would think it would no brake so easy i mean it was only spinning for like 3 seconds. the car can still drive and trun with out locking up and there is no loose of power just that sound, the guy says he knows what it is. any ideas? and is it normal to brake so easy like that?
Old Jul 15, 2003 | 06:05 AM
i put this in the wrong forum, please move it for me. need some answers or i am stuck going by what this mechanic said and i'm sure he will say anything to get more of my money.
Old Jul 15, 2003 | 08:58 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
if it coming from the diff(rear) then chances are it's screwed. the ring gear or pinion may have lost some teeth. if it's a posi rear it could also be the clutch pack has bitten the dust. a drum rear? check the drum brake assembly to make sure nothing came loose as well. you never know......
Old Jul 15, 2003 | 09:40 AM
well i just called the shop and hes telling me he cant hear were the problem is because my passanger side wheel bareing is gone and thats makeing a noise. so now i have to take it from there and get that fixed. then if it still makes the noises then bring it back. OMG i took off the tire put up the car and turned the tire and inside that diff was makeing noises, that cant be normal?? any idea? he says it could be my spyder something and thats normal is it??
Old Jul 15, 2003 | 09:54 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
It may just be the wheel bearing. They will make BAD noises when going out. Fix that and I bet your problem will be fixed. It could also be the axle shaft bearing which in the differential housing on the shaft. I bet its one or the other.
Old Jul 15, 2003 | 09:20 PM
oh man i am praying that is the problem and your right, anyway i got it at the next shop now and told him to fix the bareing. pluse my flex plate while he is at it. well there goes more money prob like 300, i am hopeing no more then that. and if it is the spider gears there goes another 300$. pray for me people, my car has been in and out of shops for 3 weeks i just want my car back!!!!!!!!!!!
Old Jul 16, 2003 | 12:22 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
"Spectacles, Testacles, Wallet and Watch..."
We're praying for you man
Good luck
Old Jul 17, 2003 | 08:40 PM
i guess all that praying came through LOL. it turned out my old mechanic really is a retart and the diff people at this other shop are just as stupid. because i brought it to a new place that my friend told me about and the second it was up on the hoist what do they see, a loose u join (that 2 other mechanics could not see). that just shows there is alot of messed up mechanics out there, make sure u got one u can trust, not like my old one.
thanks people
jason
Old Jul 17, 2003 | 11:22 PM
doug791's Avatar
yeah i was going to say it sounds like a u joint issue. I just bought a new camaro and didnt know it had aftermarket u joints that needed to be greased...well it hadnt been driven all winter and so i took it ripping around for about a day and a half and then the whole car would start shaking if i tried to drive anything above the speed limit....basically turned the existing ones to dust....new ones go on tommorow.
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
