What happens if I disconnect my carbon cannister?
Old Oct 12, 2000 | 11:25 AM
theformula's Avatar
I have a 92 formula 305 TPI and I was wondering what would happen if I disconnected the cannister. Would I get service engine lights? Would my car run crappy? I heard something about the stock PROM having the smog stuff burned in so it needs it to run optimum.
Also, does the carbon cannister still function properly laying on it's side? I built a little cold air induction setup and I had to move the cannister.
thanks guys.
Old Oct 12, 2000 | 12:11 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You mean the charcoal canister? If so, people here all have horror stories about disconnecting it, but I've had mine out of the car for over a year. At the moment I just have a little duct tape over the steel line.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 12, 2000 | 12:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't think it will work well on it's side. The "heavy" gas fumes are supposed to sink into the charcoal.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 12, 2000 | 01:36 PM
crazeinc's Avatar
I've had the canister removed for a while now with the steel tube opened (I was never really comfortable with this)....can you just remove the tube?
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website (New design in progress...very cool look)
(383/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Oct 12, 2000 | 01:43 PM
theformula's Avatar
crazeinc, I think the tube connects to your fuel tank. Which sucks. Why the hell did GM put the charcoal cannister blocking the intake for the airbox?
By the way, I have one more question. What is the engines main source for incoming air. Is it the open area on the passenger side fender? Or the two 4inch holes behind the passenger side headlight.
Thanks.
Old Oct 12, 2000 | 01:55 PM
badbird88's Avatar
from what a good friend told me a few years back was not to remove the canister. Forgot the exact reasoning but he advised not to. He was helping me work out my bugs after my 305 to 30hp 350 swap and had dissconected it for a few days to try and eliminate a problem.
xodus2002
Jul 17, 2020 09:08 AM
gta892000
Aug 11, 2019 11:16 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
