does posi make difference?
Old Jul 15, 2003 | 02:43 PM
daddy33's Avatar
Car: '85 Camaro
ok guys i just purchased a posi unit with 3.73 gears and will be installing it in a couple weeks. Right now i have a "one legged" unit with 3.08. I noticed when i try to floor it off the start, my car shakes because the car is trying to grab traction. With the new posi and 3.73 gears will i be getting off the start better? Will i be getting better acceleration when im at crusing speeds? im just curious the benefits i will get when i will put it in. I appreciate any info. Thanks!!
-Tino
Old Jul 15, 2003 | 02:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The car will try to accelerate harder under all conditions. At any given car speed, the engine will be at a higher RPM than with the other gear; if you can imagine what it would be like having an additional lower 1st gear, and losing your highest gear, then that's about what it will be like.
If it has wheel hop now, it will be far worse with the higher ratio gear. The cure is LCA relocation brackets. They are cheap and easy to put on, either before or after the rear is installed.
Old Jul 15, 2003 | 11:39 PM
iroc22's Avatar
What kind of engine are you running?
Old Jul 16, 2003 | 12:07 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
hectre13
Dec 11, 2023 08:14 AM
onefreakz
May 14, 2018 12:15 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
novaderrik
Aug 10, 2015 12:44 PM
