New Alt and Batt,no charge???After giving a jumpstart
Car: 88 GTA
Im having a problem with my 86 trans am.The other weekend i gave a guy a jumpstart and i did the big no-no,I put the jumper cables directly to both our batteries.Since then i notice my voltage started to drop more and more till a day or 2 later the battery died.I figured i fried my alternator so i took it back for a new one.The guy at pepboys said my alternator was fine.But i insisted on a new one.I used my other car to give me a jumpstart and the car fired right up but after taking the jumper cables off the battery died and the car died.So now i decided maybe my battery was just beat,so i bought a brand new battery.I put it in and same deal.Id hook up the voltmeter and with the jumper cables on its a lil more than 12 volts,then when i have the car running i pull the jumper cables and i watch the volts drop all the way down fairly fast as if the alternator isnt doing its job.I had this alternator tested too b4 i put it in and its fine and the old one was fine.The volts drop so fast its almost as if my alternators doing the opposite and instead of charging its dis-charging.Any ideas????
Car: 88 GTA
Im thinking the problem hasto do with whatever the brown alternator wire goes to.I tested the voltage going to the thick red wire and its about 12.12 volts.Then i tested the red and brown wires in the alternator harness.The red was at about 12.11 volts.With the car in accessories,the brown read about 15 volts.I think something in that brown line is messed up.As a test,I cut the brown wire and took only the end going to the alternator and applied 12 volts to it and the alternator began charging perfectly fine.Shouild that brown line be giving the alternator some voltage to turn it on and trigger it to charge?Any ideas???Anyone know the places i can check where that brown wire might run.Does it maybe go to my stereo as well as to the ignition and or fuse box???
Car: 88 GTA
So maybe ill try running it to an accessories wire then.The only thing that scares me is that when i give that brown wire juice,the alternator then squeals loud,when i take the voltage away from the brown wire the squealing stops.Im just scared the squealing might be me burning something up when i do that.
